Re: What are tips for starting cold weather H
Posted by Bob M on December 19, 2005 at 07:50:09 from (151.190.254.108):
In Reply to: What are tips for starting cold weather H posted by Randy_NE on December 19, 2005 at 06:17:16:
Sounds like you're overchoking it! In cold weather mine always start easily like this:
Give it about 1/3 throttle and pull the choke fully out. Now hit the starter. As soon as the starter begins rolling the engine (1 - 2 crank revolutions max) push the choke fully back in. The engine will fire and should continue to run at a few seconds. If it stumbles, as quickly as possible pull then release the choke again. You may need to repeat the "pull & release" step several times until the engine settles.
Key is to minimize the "choke out" time!
