Re: 1946 Farmll/IHC BN
Posted by El Toro on December 19, 2005 at 11:29:06 from (205.188.117.73):
In Reply to: 1946 Farmll/IHC BN posted by kaptkimbo on December 19, 2005 at 11:12:22:
For starters I would check the distributor cap for any cracks. Inspect the rotor too. If these appear ok you should pull No1 plug near the radiator and bring No1 piston up on the compression stroke to TDC. Someone should handcrank the engine until you feel compression
against your thumb, then look the timing mark on the flywheel. Keep cranking once you see the mark until it's aligned with the indicator. Then see where your rotor is pointing, it should be at No1 position in your distributor. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
