Re: farmall 560 (not utility)
Posted by Wardner on December 19, 2005 at 19:49:09 from (4.154.242.65):
In Reply to: farmall 560 (not utility) posted by Justin Wiseman on December 19, 2005 at 13:19:21:
Most the 560 sheet metal is interchangeable to 660 except the "side sheet". That is the dog leg at the front. The 660 is three inches taller. That three inches can be removed as it is attached with spot welds.
There are a few diferences depending on whether the tractor is gas or diesel. The same applies regarding diferrent hydraulic setups. I also noticed a few parts have a serial # cut-off which would indicate early tractors are slightly different than later tractors.
You should indicate what parts you need and I can look them up. I have a 460 book too. I think there is alot of interchangeability on all three models.
