Re: Rebuilding a rear pto unit Farmall 400
Posted by Farmall450man on December 20, 2005 at 05:08:07 from (12.44.216.110):
In Reply to: Rebuilding a rear pto unit Farmall 400 posted by Kelly C on December 19, 2005 at 20:51:35:
Kelly,
Have you adjusted the bands? The IT manual tells how to do this. New bands are pretty high. I got some used ones from JP's for a reasonable price. The adjusting screws are under the little cap close to the engagement lever.
