Re: Reasons a 656 sticks in reverse??
Posted by Allan in NE on December 20, 2005 at 05:19:50 from (148.78.243.26):
In Reply to: Reasons a 656 sticks in reverse?? posted by Wayne Rimathe on December 20, 2005 at 04:39:23:
Wayne,
It has peeled a roll pin either at the shift lever or the right side shift rail fork.
If you take off the cowling, battery cover, battery and tray and then aggresively work that shifter in low/reverse and you'll be able to see which one is not moving right, unless it is that joker down inside the box, in which case, you've got to pull the floorboard and lift the cover.
I'm bettin' it is the top one right under the cowl.
Could be a bad fork also, but chances are more towards the roll pins.
Allan
