Re: question about f-20 clutch and flywheel assem
Posted by Ron in Nebr on December 20, 2005 at 06:29:16 from (12.192.38.130):
In Reply to: question about f-20 clutch and flywheel assembly posted by Jonathan Brown on December 20, 2005 at 05:08:30:
Are you going to be using this tractor frequently for heavy feild work or even antique pulling? If so, by all means go ahead, do it right, and have the flywheel surfaced while you're at this point to avoid any potential premature downtime in the future.
On the other hand, if it's only going to get the limited and light use that alot of "restored" F-20's get(shows, parades, pulling a haywagon occasionally) and the flywheel truly isn't grooved, then feel safe to go ahead and scuff the surface with sandpaper or emery cloth and put it back together. The clutch will probably outlast you.
