Re: 1466 $$$
Posted by El Toro on December 20, 2005 at 08:33:34 from (205.188.117.73):
In Reply to: 1466 $$$ posted by Michael Sheik on December 20, 2005 at 07:35:20:
A major sleeve and piston kit cost's about $1225.00 from Wenger in Myerstown. That includes
your gaskets, rod bearings and main bearings. Your crankshaft needs to be measured and ground if needed to determine which bearings to order.
I would want to pull the engine too, as the Vet has suggested. Engine probably should be degreased too. If it has removable cam bearings
I would have new bearings installed. This and close tolerances on your crankshaft bearings determines good oil pressure. Hal
