Re: Farmall H gears
Posted by Daniel Patterson on December 21, 2005 at 04:48:37 from (24.34.16.59):
In Reply to: Farmall H gears posted by Daniel Patterson on December 20, 2005 at 18:59:00:
Well this is not an easy case because the previous owner modified it with a truck front end, an industrial loader and a cab. Basically the only farmall left is the engine, transmission and rear end. It is diffently an H engine. And the transmission gearing looks identical to the breakdown at the dealer. It is even cast into the cover R-1-2-3-4. The dealer thinks it maybe an industrial model built with the H engine. The serial tag is covered by the hydraulic tank but I will see if I can get it. When I try to shift into what would be 5th nothing happens, no grinding or anything. That shift fork rail only moves for 4th gear not fifth. And the wheels are definitely H wheels. According to the style PTO it has it would be on of the first 15,000 H's produced... Any help would be greatly appreciated.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
