Re: Farmall H gears
Posted by Daniel Patterson on December 21, 2005 at 08:26:05 from (24.34.16.59):
In Reply to: Farmall H gears posted by Daniel Patterson on December 20, 2005 at 18:59:00:
Ok I already have the transmission apart but I do in fact remember that sunken bolt. The only number I can find is cast into the rear 8276 DB. All the gears except the two constant gears are worn badly and some have broken teeth. As far as the steering it has an aftermarket straight hydraulic system. No H steering column...
