Farmall Tractors Discussion Board
Re: starting on gas switching to diesel
Posted by Mudcat49 on January 02, 2000 at 21:04:58 from (209.26.211.71):
In Reply to: starting on gas switching to diesel posted by bob on January 02, 2000 at 10:37:51:
We used to run a lot of TD-6's and TD-9's as well as UD-6's and UD-9's with the old crank on gas switch to fuel type motors. The problem we had here in hot South Florida with the heads cracking was not the motors cooling down right, but the motors running hot and cold water being added too fast.
Post A Followup
: Re: Re: starting on gas switching to diesel
