Re: Any sugguestions
Posted by the tractor vet on December 21, 2005 at 17:34:54 from (4.124.79.5):
In Reply to: Any sugguestions posted by David N on December 21, 2005 at 14:31:39:
Pull the valve cover and turn it till both valves on # 1 and loose then look at the timming marks on the flywheel and set as per spec. , if ya got the pump off and the shaft still in the gear make sure that the dot on the pump shaft is aligned with the DOT inside where the shaft goes.
