Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: starting on gas switching to diesel
Posted by Redfan on January 03, 2000 at 01:13:01 from (203.87.53.9):
In Reply to: Re: Re: Re: Re: starting on gas switching to diesel posted by T'other Fred on January 02, 2000 at 19:19:50:
Fred, I think an idle for a reasonable length of time would be sufficient. I must add that where I live and farm is rather temperate, and the cooling down was not as big a problem as they experienced in the Snowy Mts. with the TD24s. The tractors we had most experience with in this area were WD9, WD6, TD14, TD18 & TD9. Our 6 series Dozers were more likely to be the British BTD6. One more point in the cooling down procedure, I was always told to switch them back to Petrol mode and run them for a while to help "clean" out the Auxilliary combustion chamber before shutting down. When the engine had stopped, it was important to put it back on Diesel mode to help the Starting valve cool slowly and prevent it from distorting. Regards, Redfan.
Post A Followup
: Re: Re: Re: Re: Re: Re: starting on gas switching to diesel
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
