Re: Cavitation 66 series tractors
Posted by Brownie 45 on December 23, 2005 at 03:54:37 from (207.177.82.187):
In Reply to: Cavitation 66 series tractors posted by DHD on December 20, 2005 at 17:02:49:
On the experience & advice of a mechanic who worked on IH's forever, we put a ground wire ( #8) from the alternator mounting bolt to a 3/8 inch bolt on the water outlet/ thermostat housing. The mechanic`s theory was cavitation caused by electrolysis in the cooling system was causing the problem.
