Re: Original 12V M???
Posted by Janicholson on December 23, 2005 at 06:45:34 from (66.173.50.141):
In Reply to: Re: Original 12V M??? posted by NDS on December 23, 2005 at 05:53:28:
Gas start, diesel run "M"s and many other IH/Farmall units were 12v (pos ground)from the factory.
There are no problems making the switch. It can even be easily switched to common Negitive ground.
Use a neg ground voltage regulator, repolarize the generator, and use a 12v coil for no resistor (or put in a resistor with original coil) with the neg terminal connected to distributor points.
