Re: Decals For side hood panels on 350 Farmall ...
Posted by Wardner on December 24, 2005 at 09:37:07 from (4.154.246.137):
In Reply to: Decals For side hood panels on 350 Farmall ... posted by migraine on December 23, 2005 at 17:47:35:
A good sign shop that does alot of business will have the vinyl in a shade that is very close. It would probably cost less than five dollars for enough material for both panels. You should probably get a little extra so that you can practise applying the decal. Air bubbles can be a problem. Listen well to the dirctions from the sign painter.
Find a 350 with original paint and make a tracing similar to how people trace grave stones. That will be your template for cutting the new panels.
