Re: speed sleeve for an h axle
Posted by RN on December 24, 2005 at 23:23:16 from (166.126.218.219):
In Reply to: speed sleeve for an h axle posted by tn terry t on December 24, 2005 at 21:17:04:
Check new seals- new seal thinner than original Chicago Rawhide #, offset slightly so it doesn't ride in original grooves. previous postings say use 2 new seals- 1st one installed backwards with lip to inside of groove and the outer seal will be outer lip outside of groove. Grease well and pack grease between seals. worth a try if you have old seal to compare. RN
