Re: Farmall C Engine Question
Posted by Janicholson on December 25, 2005 at 09:45:54 from (66.173.50.133):
In Reply to: Re: Farmall C Engine Question posted by SWSimplicity on December 24, 2005 at 19:24:55:
I think they are not removable from the top, and the cam must be removed to pull them from the bottom. They (if I recall correctly)are mushroom lifters more or less "T" shaped. I would open the bottom end and look at it. What you will find is a rusty lifter in its bore. From the top looking into the push rod hole (though you won't see much) you will be able to see where to put PB Blaster or other penetrating fluid. Turn the engine till the lobe on that lifter is down, away from lifter. Use a nice piece of 5/16 mild steel rod with a ball shape ground into one end. Place this in the pushrod hole in the resess in the lifter, and mark the rod with tape just where it goes into the head. Tap gently using a small ball peen. If it moves any at all (probably), go below and use a piece of 1/2" birch dowel rod to tap it back up (do not whack hard in the up direction the lifter "mushroom" can crack off, then you are into a cam removal!!). If it moves continue (up down, up down) till it is free and loose. Then oil it with engine oil cut 50/50 with gasoline. The rusty stuff will drip out the bottom. Do this till the rust stops comming out (might be five minutes, might be an hour). Rust is Iron Oxide a very nice abrasive, so it is important to remove. If it does not move, use a propane torch to heat the casting in the area of the bore from below, and tap more. A propane torch will not have the heat capacity to over heat the system if used for 10 minutes or so. if there is rust on the cam lobe polish it, and the lifter contact area with 400 grit silicon carbide paper. Spray it clean with brake clean, and relube with lubriplate engine assembly grease on the contact surfaces, and straight engine oil down from the top. Good luck. I got help on this engine from this forum little more than a year ago. The issue was identical (we thought the head or pushrods, or cam, or rockers or valve job were causing geometry problems. It was 6 stuck lifters. Good tapping. (never tap on the lifter with the cam lobe up!!!). JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
