Re: 404-Carb problems
Posted by herkpilot on December 26, 2005 at 16:44:50 from (71.11.235.59):
In Reply to: Re: 404-Carb problems posted by El Toro on December 24, 2005 at 08:55:49:
That was the problem. I used a couple 1/16 drill bits to clean out the holes and it fired right off. Trouble now is I can"t get it above barely running (I hesitate to call it an idle). The rusty sediment bowl I replaced had a a standpipe modified to it to keep the junk out of the bowl, but I haven"t seen too much in the bowl and the screen is clean but I have a clear inline filter that hardly fills up. I think I"ll verify the governor"s adjusted correctly, fill up the tank and play with the needle valve until it works. Good news is the transmission didn"t blow any seals when I backed it up 30 ft before it died.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
