Re: Farmall H won't idle down
Posted by Brownie 45 on December 27, 2005 at 04:06:45 from (207.177.82.89):
In Reply to: Farmall H won't idle down posted by Arvada Farmall Rookie on December 26, 2005 at 16:30:59:
After checking everything else, see if the throttle plate is mounted on the throttle shaft the right side up. After a mechanic rebuilt the carb on our smta, it wouldn't idle down, probably 800 to 900 rpm was all. After many years of this, I took the carb off , and found the throttle plate problem. The throttle plate has a bevel on the "edges" so it will close tight on the bore of the carb. Hope this helps.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
