Farmall Tractors Discussion Board
Re: Re: Re: Wiring a '44 B
Posted by The Red on January 03, 2000 at 09:41:35 from (206.246.187.2):
In Reply to: Re: Re: Wiring a '44 B posted by The Red Ed on January 03, 2000 at 09:27:58:
I think your system is like my H. Here we go.
As you look at the back of the control switch, the wire from the field side of the generator goes to the lowest post that has a resistor to the left of it. That supposedly gives you the low charge. To get dim lights, hook that wire to the screw just right of the small resistor that is on the light switch portion. If you want steady bright rear light, hook that wire on the screw straight below the dim screw at the bottom of that square box. To wire the lights themselves, run a wire from the right post of the ampmeter to the screw that leads into the fuse. If you don't have a fuse, wire on the other side.
Post A Followup
: Re: Re: Re: Re: Wiring a '44 B
