Re: Tractor Storage
Posted by Randy-IA on December 28, 2005 at 15:44:29 from (207.177.83.5):
In Reply to: Tractor Storage posted by TKN on December 28, 2005 at 14:32:14:
Hi , you're thinking outside the box ( HeHe ) so to speak . The temp inside the box with no ventilation would do bad things to the tires and the gaskets if not the paint and steering wheel and grease and , and , and .... It may help some to put a wood frame inside of the box and insulate it as you would your house but then there might not be enough room to use it for anything other than a shop area . We use semi trailers as job storage and they have aluminum tops ...here in Iowa they get so hot even with the rear wide open it's not healthy to stay in them for any longer than needed to get what you need . Someone else may have a better alternative ? ...Randy
