Re: B will not start
Posted by JT on December 29, 2005 at 06:12:33 from (70.226.202.54):
In Reply to: Re: B will not start posted by El Toro on December 29, 2005 at 05:15:48:
Hal,
As usuall, good info, thank you. When I put it at TDC, took out #1 plug, had valve cover off, watched valves cycle, when intake valve closed, put finger in plug hole, turned over with crank until felt air blowing out around finger, put screwdrive in plug hole, followed piston to top of trvel, got under tractor found DC on flywheel, aligned with pointer. That is why I feel it is on TDC #1 plug. Need to take mag off and check internal mag timing and see if that is problem. That is the only thing it can be, there is nothing else. Again, thank you for the ideas and input.
Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
