Re: B will not start
Posted by captaink on December 29, 2005 at 07:39:13 from (66.115.214.56):
In Reply to: Re: B will not start posted by JT on December 29, 2005 at 06:16:45:
Double check the wires in the cap and make sure they are correct. It sounds like at least one cylinder is firing with the exhaust valve part way open.
(Youngest son changed plugs this weekend and about blew the muffler apart cause the wires were on wrong. Yup, you guessed it, learning opportunity.)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
