Re: international 240
Posted by EricB on December 30, 2005 at 06:21:34 from (216.209.84.11):
In Reply to: international 240 posted by randy on December 30, 2005 at 06:10:08:
Might well be a fuel supply problem. I have had simlar gremlins. Sounds like you have checked out the spark. Clogged fuel line may be causing starvation at higher throttle. Alternately, the air fuel mix at the carb could be too lean.
3 things you need to start fuel, spark, compression.
Just a thought!
