Re: Cub won't run
Posted by El Toro on December 30, 2005 at 12:49:31 from (64.12.117.13):
In Reply to: Cub won't run posted by WCB on December 30, 2005 at 11:45:01:
Are you sure the choke butterfly is open? Sounds like its getting too much fuel. Were the plugs wet? Pull the coil wire from the cap and hold within 1/4" of a good ground. Then attempt an engine start and watch your spark from the coil wire. Should be good hot blue spark. Use a pair of insulated pliers to hold that wire. If you have good fire here check the fire at your plugs.
Hal
