Re: 650 Diesel
Posted by Mcred on December 30, 2005 at 12:49:48 from (69.66.89.232):
In Reply to: 650 Diesel posted by jaybird2 on December 30, 2005 at 05:06:35:
jaybird2 the 650D are a nice tractor to run as Paul stated, we are in the middle of restoring a 650D there is one thing that I would definantly do before you buy it, we always crack the oil plug first before it has been run and if you get antifreeze out of there I would shy away or offer less because overhaul on them moters are very expensive, good luck thou, we have four gas start diesels and are very happy with them
