Re: Cub won't run
Posted by El Toro on December 30, 2005 at 14:36:00 from (152.163.101.13):
In Reply to: Cub won't run posted by WCB on December 30, 2005 at 11:45:01:
Is this 6 volts or 12 volts with a ballast resistor? If you have a bad resistor the engine
will run some until you release the starter switch. Hal
