Re: Super A won't start - HELP!!!!!!
Posted by El Toro on December 30, 2005 at 16:44:07 from (64.12.117.13):
In Reply to: Re: Super A won't start - HELP!!!!!! posted by Mark in TN on December 30, 2005 at 16:32:51:
If you have good vacuum and spark I would put on a good thick glove and hold your hand over the carburetor throat while someone tries to start it.
This should pull that atomized gas into the engine. I would set those valves to .017" too. Hal
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
