Re: splitting a 400
Posted by Kelly C on January 01, 2006 at 10:07:19 from (63.171.43.140):
In Reply to: splitting a 400 posted by super99 on January 01, 2006 at 07:31:09:
This works good for the front. Just take 2 lenths of angle iron, cut 2 or 3 inches off the bottom. Weld that into a square at the bottom.
Cut the right size square for the bottom plate. Drill 3/4 inch hole in the center. Weld a 3/4 inch nut over the hole. Thread 3/4 rod into that/ with a 3/4 inch nut welded to the bottom of the rod. Makes it adjustable.
Use a 5 ton jack on the rear to split.
I also used 3/4 rod to keep the halfs aligned to do clutch.
I tried the cherry picker on the front and that turns into a mess. It will pivot on the wheels and get out of alighnment.
