Re: transmission bearing retainer Farmall H
Posted by SGT K on January 01, 2006 at 11:46:02 from (216.125.213.242):
In Reply to: transmission bearing retainer Farmall H posted by steveb05 on January 01, 2006 at 08:19:34:
Steve,
You can also pull the PTO and remove the cap screw that holds the bull gear on. If you remove the four bolts that hold the bearing retainer and seal on you can slide the axle out enough to move the bull gear back and to the side to take out the bull pinion assembly. There isn't a lot of room, but it can be done.
I once broke a cast Bull pinion assembly by pulling it out without moving the bull gear (DOHHH!!##XX%%). A mistake I will never make again!! My local salvage yard had one, and they should not be hard to find. When you go back together make sure you roller bearings are tight in the cast assembly. If they are not you will have excessive end play. Let us know how you come out and if you have problems, there are a lot of folks on here with a lot more experience than me. Buy a tractor manual first chance you get, I sure should have ;)
Good Luck
Paul
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
