Super A Water Temp Indicator
Posted by stan2270 on January 02, 2006 at 07:28:11 from (24.159.182.132):
Hi folks! I need ideas on fitting a water temp indicator for my 53 super A. The C-113 engine has been re-built and a water pump was added. This means the bottom inlet elbow where the SA temp probe fits (for thermo siphon system) will not work for my set up. I thought about using a Super C outlet elbow but this does not work for 2 reasons: 1) the pipe dia for the radiator hose is bigger and 2) the elbow is designed for the taller SC radiator. I also thought about using the drain plug to "plumb in" the temp sensor but dia here is to small and there is not enough material to machine a custom bushing. Has anyone solved this problem before? Are there other points on the block where a temp probe could be attached? What about modifying the radiator tank to accept a fitting? Any ideas and all comments welcomed! Happy New Year!
