Re: 6v to 12v conversion ... ignition problem
Posted by Janicholson on January 02, 2006 at 10:40:09 from (66.173.50.55):
In Reply to: 6v to 12v conversion ... ignition problem posted by Randy Glasnapp on January 02, 2006 at 10:14:29:
The problem may be as follows: The starter, battery, cables and connections may be the problem. When starting, the starter motor draws in the area of 275-350 amps (or more if cold). This draws enough current to lower the battery voltage to about 10 V (or much lower if any of the above are less than ideal). If you want to check this, place a volt meter across the battery terminals (on the posts, not the clamps) have some one crank the engine. If the voltage drops to less than 10 v. I would upgrade components/charge battery, new battery, bigger cables, eic. till it remains high. An instant test is to run the ignition off of a seperate battery from the one used to start it. If ti runs, the above is probable cause. I like to use a resistor style coil with a MoPar, or Chev ballast resistor to the key. And a resistor bypass wire from a Ford type 4 post solenoid, on the "I" terminal. This gives the coil 10-11 volts while starting, and then drops it to about 6-7 volts in operation. Good luck, JimN
Home
| Forums
Today's Featured Article -
Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
