Re: 6v to 12v conversion ... ignition problem
Posted by El Toro on January 02, 2006 at 11:22:15 from (205.188.117.73):
In Reply to: 6v to 12v conversion ... ignition problem posted by Randy Glasnapp on January 02, 2006 at 10:14:29:
I think you should have a wire from the small terminal on the solenoid to a key type starter switch. The switch would have a separate terminal that goes to the s terminal on the starter solenoid. The starter would engage the starter drive when you attempt a start. It would have a separate terminal that would feed voltage to your coil.
This connection would have voltage there when the key was in on position. I think you're losing your voltage to the coil once you attempt a start. Hal
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
