Re: Farmall A Magneto
Posted by El Toro on January 02, 2006 at 11:39:52 from (205.188.117.73):
In Reply to: Farmall A Magneto posted by Tony T on January 02, 2006 at 09:51:07:
You should file and clean those points with a cotton swab dipped in alcohol. Set the point gap to .013". Pull the coil wire from the cap and hold within a 1/4" of a good ground on the tractor while someone cranks over the engine with the starter or with the hand crank. Should be a hot blue spark. If you have a good spark then attempt an engine start. You probably should install a new set of points & condenser. If you need to pull the mag from the engine make sure you notice where the rotor is pointing and write it down. The rotor needs to be in this position so your mag will be in time when you reinstall the mag. Don't crank the engine when the mag is removed. Have you tried to start the engine since it quit? It may start if the engine is cold. If it does a good indication of a bad condenser or coil. Hal
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
