Re: 756 Farmall carb problem?
Posted by Janicholson on January 02, 2006 at 14:17:08 from (66.173.50.142):
In Reply to: 756 Farmall carb problem? posted by Loren in MN on January 02, 2006 at 13:42:56:
The fact that it runs indicates that the fuel shutoff being shut is not the primary issue. I believe there is a particle of dirt/crud in the main jet. Take out the Shutoff valve and you (if I remember) also remove the main jet. It may be partially plugged. If no better, pull the bowl off and clean things, squirt carb spray through jets, and look for junk in the bottom of the bowl. It may take a new gasket if the old one gets ripped on removal of bowl.
Otherwise it is time for a rebuild, but my guess is this will make it new.
JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
