Re: Farmall B won't stay running fixed maybe
Posted by P Backus on January 02, 2006 at 21:04:29 from (69.128.32.197):
In Reply to: Re: Farmall B won't stay running fixed maybe posted by Carpenter turned shade tr on January 02, 2006 at 17:19:14:
It sounds like you"ve got a case of the gremlins! The fuel
problem and the starter problem are unrelated, but as I always
tell myself, anything that moves can break. As with all starter
problems, check to make sure that the battery terminals are
clean and tight, the ground is clean and tight, and all other
terminals are clean and tight. Make sure that the battery is
charged. If you have a volt/ohm meter, check for voltage at the
starter terminal when you push the start button- if not there,
move back down the cables until you find voltage. That should
isolate your problem. If the starter has voltage, tap on it a bit.
Then take the bolts that hold it on loose- sometimes the gear
jams against the flywheel and that should free it up. The starter
grounds through it"s base, so that must be clean and tight.
Let me know what you find or give me more symptoms- I enjoy
the mental exercise! These machines are tough and simple and
reliable, once we get the bugs worked out.
Paul
