Re: ihc m shorting out 2 center plugs
Posted by P Backus on January 02, 2006 at 21:41:29 from (69.128.32.197):
In Reply to: Re: ihc m shorting out 2 center plugs posted by mark geiger on January 02, 2006 at 17:00:54:
Are those Champion plugs? If so, the first thing I"d do is get
something else. For some reason Champion plugs are many
times bad right out of the box. If you don"t believe me, just post
something about them and watch the response you get!
A good test would be to move those two center plugs to the
outside positions and then see if the problem follows the plugs
or stays with the cylinders. If the latter, then it must be in the
wires. Same test could work there.
I don"t remember, did you do points/plugs/cap/rotor/wires?
My guess is the plugs themselves though.
Paul
