Re: How deep to cut a crank
Posted by Merlin on January 03, 2006 at 05:31:01 from (209.205.160.13):
In Reply to: How deep to cut a crank posted by biggerred on January 02, 2006 at 16:26:15:
Both ways sound logical and I"m not saying either way, but I have always heard and used the terminology "over sized" bearing and/or piston. Thats because if the crank was ground .010, it would be undersized and the bearing would have to be .010 over sized to take up the slack.
