Re: oil filters
Posted by captaink on January 03, 2006 at 08:47:08 from (66.115.214.56):
In Reply to: oil filters posted by Tyler in SD on January 01, 2006 at 17:14:00:
Oil filters are pretty much fool proof. If it makes a difference, they will only fit one way (like on A, B, C, H, M) they are larger on the end that goes into the filter base, the cover won’t screw down tight if the element is in upside down. On the 560, it doesn’t matter, the filter is symmetrical.
