Re: Front Wheel Bearing Removal
Posted by Janicholson on January 03, 2006 at 09:25:24 from (199.17.6.162):
In Reply to: Re: Front Wheel Bearing Removal posted by janicholson on January 03, 2006 at 07:06:33:
I had to end my earlier post early.
I needed to add that the bearing should be fairly easy to get off of the spindle. If it is hard to remove, there may be scaring on the spindle from a bad bearing in the past, or the one on there now. The new bearing needs to be greased (packed)and placed in the hub followed by the oil seal. If the new bearing does not go on the spindle with medium finger pressure and careful positioning, then the shaft should be polished with 240-320grit abrasive strip. Polish round and round evenly, till the high spots are gone. If there is a groove, or the original bearing has worn a depression in the spindle, it is probably best to consider a new/used good spindle. Welding and grinding the old grooved spindle is costly machine shop labor.
Good luck, jimN
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
