Re: Super C Bull pinion seal
Posted by Haas on January 03, 2006 at 09:55:25 from (12.65.73.138):
In Reply to: Super C Bull pinion seal posted by JonT on January 02, 2006 at 17:10:10:
I think you need both the shaft seal and the "O" ring seal. I believe the O ring seal serves as a gasket to keep oil from leaking around the brake plate that is bolted to the transmission housing. The shaft seal looks to be mounted in this plate. I've not had the seals out of one with disk brakes, but have done the old band brakes. On the band brakes you need a seal washer and the oil seal. The seal washer goes under the retainer washer that holds the drum on the spline. On these the shaft seal runs on the brake drum and the washer keeps oil from leaking through the splines and out around the end of the shaft. I think that O ring serves a similar function on the disk brakes.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
