Re: Hard starting 1206
Posted by the tractor vet on January 03, 2006 at 11:09:15 from (4.124.78.234):
In Reply to: Hard starting 1206 posted by 06'er on January 02, 2006 at 14:08:02:
The DT361 is not and engine for a novice to rebuild as it has some quarks and after rebuild if not done correctly will come unguled fast. When they are correct in every way they will start with out either sometimes down to 0 . Propper valve placement in the head as far a s valve resession or protrusion is one of the factors as to how well they will start and how well the rings seat in , then comes the pump and injectors if the cranling pressure on the pump is low and the cracking or breaking pressure of the injector is down then the spray pattern will be off and this will lead to a hard start along with the timming of injection. To do a super job on rebuild one MUST have the block done from top to bottom and if it has not had the bore redone and the oversized sleeves installed to correct the core shift that does happen in the 361-407 and the sleeve checked from top to bottom for any wrinkening and trued up it will seeze up fast and send a rod out the side of the block . So a line bore , decking of the block correcting the center line of the bore total rebuild of the head and getting the valve heads set to correct hight fitting each piston to the bore that it is going to be installed in and even a balance job is in order then ya got a engine that will give you years of service . And don"t be cheep on it use only quality parts and service .
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
