Re: Charging question for Bob M
Posted by Janicholson on January 03, 2006 at 11:32:59 from (199.17.6.162):
In Reply to: Charging question for Bob M posted by JohnG(TX) on January 03, 2006 at 11:23:46:
There are 12v gennerators (stock Delco for use on MD and other units) that replace yours directly. You would need only the Generator and regulator. I would use negative ground regulator, and neg ground the battery. (you will need to repolarize generator).
I don't think LED lights are ready for prime time yet (unless very expensive, and not at all stock looking).
If it were mine I would use a Mitsubishi Alternator and be done fooling around with maintinance. Good hunting,
JimN
