Re: Charging question for Bob M
Posted by Bob M on January 03, 2006 at 12:02:53 from (151.190.254.108):
In Reply to: Charging question for Bob M posted by JohnG(TX) on January 03, 2006 at 11:23:46:
Hey John – I have a Super M set up pretty much like yours (high compression pistons, LP head, etc). I quickly found that even with the complete starting system in “like new” condition it was it difficult to crank with the stock, 6 volt setup. However with a 12 volt battery it spins up and starts very nicely. So my advice here would be to go to with 12 volts. ---- Regarding the existing 6 volt generator, yes you can get 12 volts out of it. However the output will be less and it will need to spin faster than normal before it begins to charge. Also the generator will tend to get hot if you run it for long periods - which will shorten it’s life. Note also that if you install a 12 volt regulator you still risk burning out the generator due to overload unless the regulator is readjusted to match the current characteristics of the original generator. ---- From my perspective a 12 volt alternator conversion is the best solution from a cost, efficiency and maintenance standpoint (that’s what’s mine has). And you can easily hide an alternator up under the hood on an M – you can only tell it’s there by getting down on your knees and peeking up under the hood. ---- However if you are a stickler for originality want a generator here’s a couple options: 1 – Get the stock generator reworked to 12 volts at your starter/alternator shop. Cost is probably same as a stock 6 volt generator rebuild - about $100 - $125 or so. 2 – Replace the generator with a 12 volt one from an IHC diesel of the same era (MD, WD-6, WD-9, etc). By swapping pulleys will it look (and I believe will fit) same the original generator. Of course either of the above requires a new voltage regulator too – figure another $40 or so for that. Hope this helps...
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
