Re: Charging question for Bob M
Posted by MI Mark on January 03, 2006 at 12:06:06 from (205.188.117.73):
In Reply to: Charging question for Bob M posted by JohnG(TX) on January 03, 2006 at 11:23:46:
you can also get a delco alternator to put on in place of the generator then all you need is the one wire from the battery via the on off switch better than the generator they were real pain to keep working
