Re: Charging question for Bob M
Posted by John T on January 03, 2006 at 15:05:38 from (66.244.90.98):
In Reply to: Charging question for Bob M posted by JohnG(TX) on January 03, 2006 at 11:23:46:
John, I agree with the good gents below, I also have used 6 volt Generators to charge a 12 volt battery and none ever went bad. Basically, a genny dont know what voltage its supposed to crank out, that increases as you turn it faster and/or increase its field current. HOWEVER that being said, IM ONLY SAYING IT WILL WORK, NOT that its the best way or engineering proper. The proper way would be for a genny shop to rebuild the genny for 12 volt use (they can change out the Fields n Armatures etc, inside the old case). If you are running more current through the Field windings then it were designed for, it could eventually be harmed and also even though it works, it may well not supply as much or enough energy as if a proper 12 volt genny were used. BOTTOM LINE its much better if you use a 12 volt genny or go the alternator route. YES when I used a 6 volt genny to charge 12 volts I replaced the VR with a 12 volt VR. If theres no local genny shop to rebuild your exisitng case for 12 volts, check with Kenneth down there at Kenneths Classic Generator in Texas, he will buid a nice one that also looks beautiful as well as original. John T
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
