Re: 350 utility hydraulic relief valve
Posted by DYNA490 on April 08, 2009 at 18:07:27 from (72.228.74.5):
In Reply to: Re: 350 utility hydraulic relief valve posted by bc on April 08, 2009 at 17:31:27:
I put a guage on the system and the pressure only goes up to 1200psi at idle or high rpm. What do these systems run for pressure?
