Re: Crank shaft
Posted by BobOHIO on January 03, 2006 at 17:52:21 from (66.153.35.230):
In Reply to: Crank shaft posted by Famall lover on January 03, 2006 at 12:54:07:
Farmall- I've used the white lubriplate assembly grease on small engines and it was fine. I use clean engine oil on the rings and cylinders. If all clearances are correct it is not a problem the engine is tight to turn over. Rebuilt a 350 Chevy that was very tight after assembly. That was 13 years ago and still running strong. Just remember to check all clearances and you will be ok.
