Re: Where there's smoke...
Posted by SCOTT#2 on January 04, 2006 at 04:16:03 from (138.88.71.135):
In Reply to: Re: Where there's smoke... posted by gene bender on January 03, 2006 at 03:33:02:
Everything is original, switch, lights, etc. The resistor is connected to the right terms. The resistor gets warm but doesn't smoke on dim. The smoke is coming from inside the light switch its self not the wire wound load connected across the terms. Wonder if I can take that switch apart? The fact that the fuse was removed when I got the tractor tells me that there was a previous problem with this switch.
scott#2
