Re: 656 Hydraulics
Posted by Allan in NE on January 04, 2006 at 08:03:53 from (148.78.243.24):
In Reply to: 656 Hydraulics posted by jkspratt on January 04, 2006 at 07:02:29:
JK,
Just to add to the Vet's comments.
They are both mounted behind that square plate on the left side of the tractor just forward and under your clutch. The front pump handles the power steering and remotes; the back (piggyback) pump runs the hitch only.
Just take out the outer row of bolts initially to remove the mounting plate along with the pumps attached. Don't forget all the o-rings too.
The plate sets on dowel pins, so is very easily to re-align when you're goin' back together.
Allan
